Compmall
Input voltage between 9 and 36 V(DC)
The DRPC-330-A7K embedded PC from Compmall is a fanless PC based on a Marvell Armada 7040 quad-core processor with a clock frequency of up to 1.4 GHz, a system-on-chip solution originally designed for gateway tasks.
© Compmall
The DDR4 memory with 4 Gbytes of storage space is already onboard. Two Ethernet ports are relevant for the fast transfer of large amounts of data, one of which has the option of adding an SFP+ module to achieve 10 GbE. Connection to the wireless network is also possible via an M.2 2242/2280-B key module with SIM card slot. WLAN can be integrated if required. External devices can be connected via RS232 and RS232/422/485.
The COM ports have 2.5 kV insulation to increase interference immunity. The embedded PC from Compmall offers a USB 3.2 Gen1 port as an additional interface. The data is stored on a pre-installed eMMC5.1 flash card with 32 Gbyte. A micro SD slot is also available.
