Mobile IPCs
Quelle: B&R Industrial Automation,
Modularly expandable
B&R is expanding its product portfolio for mobile machines to include a PC with an Intel Core i processor in protection class IP69K, which is specially designed for operation in harsh environments.
© B&R Industrial Automation
Its performance makes it ideal for smart machines that communicate with each other and send data to the cloud. The processor is scalable over a wide range: from Celeron with 2.2 GHz to Core i7 with 2.8 GHz. It offers up to 16 GB RAM and 48 GB flash memory and is equipped with a TPM module. The PC supports standard operating systems such as Windows 10 IoT Enterprise and Linux and can be used as an edge controller. B&R offers the common OPC UA and MQTT protocols for communication between the machines and to the cloud. The mobile computer is resistant to vibrations, shock, salt, UV light and oil and does not require a fan despite its completely enclosed housing. It is maintenance-free and has a specially developed temperature management system and can therefore be used at a surface temperature of -40 °C to +85 °C. In addition to a wide standard voltage range from 9 V to 32 V, the PC has integrated load dump protection. It can be modularly expanded with additional communication interfaces via two internal slots.
Dold
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine is no longer moving in a dangerous direction, the safety gate can be released immediately when a standstill is detected.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
Virtual HMI
Platform-independent remote access
Usually, the control of processes with a PLC runs fully automatically after the initial parameterization. In some applications, however, it is necessary for the operator or technician to be able to call up and set the process data at any time.
