Spectra at SPS Connect
Inka Krischke | Tiffany Dinges,
Long-term availability and fanless
The 3.5-inch embedded board LE-37N from Spectra is equipped with the powerful 'Intel Whiskey Lake Core i7-8565UE' processor, which is available until at least 2027.
© Spectra
It is supported by two DDR4 memories, which can be expanded up to 32 Gbytes. Mass storage devices can be connected via two SATA ports, and the low TDP value of 15 W allows the construction of compact and fanless embedded systems. High graphics performance is ensured by the Intel Generation 9.5 HD Graphics GPU, which enables the connection of up to three independent displays in 4K quality via LVDS, HDMI and DP port.
External peripherals can be connected via four USB 3.1 Gen 2 and four USB 2.0 ports. Two Gigabit Ethernet ports are available for the wired network connection. Functions such as Wi-Fi or Bluetooth can be easily retrofitted thanks to an M.2 2230 slot. The input voltage range is specified as 9 to 35 V(DC) and the operating temperature as 0 to +60 °C.
Would you like a little more?
First-hand news every week - that's what the Computer&AUTOMATION newsletter offers you.
© WEKA Trade Media
Subscribe to our newsletter and keep your finger on the pulse of automation. Stay up to date with us. We provide you with the latest news, exciting interviews, guest commentaries, application-oriented technical reports and new products.
Click here to subscribe.
Spectra
HMI and PLC in one
The all-in-one control units of the 'Uni-Stream' series from Spectra combine a touch display and the control unit with numerous combinations of analog and digital inputs and outputs in a compact housing.
Wöhr
Two new surface-mounted keyboards
Wöhr is expanding its 'Surta' industrial keyboards with versions 15 and 16, which have been specially developed for environments such as medical and dental areas, the pharmaceutical, clean room and food industries, as well as general industry and...
