ICO
Optional with Windows 11
With the Panelmaster models 155 and 215, ICO Innovative Computer offers two Panel PCs that enable Windows 11 installation.
© ICO
The panel PCs from ICO Innovative Computer come in a black aluminum housing. The displays are available in sizes of 15 and 21.5 (SCL) inches. As the touch displays are capacitive, multi-touch control is possible. Both Panel PCs have a VGA and HDMI port for graphic output. The panels work without a fan and are versatile thanks to 8 Gbyte RAM in combination with a 128 Gbyte SSD. The core of the panels is the 11th generation Intel Celeron J6412 processor with a base clock speed of 2.0 GHz, providing sufficient computing power for a wide range of industrial applications. Operating temperatures of 0 to +50 °C are specified. Thanks to the IP66-protected front, the Panel PCs can also be used in harsh conditions. The power supply is guaranteed by a power supply unit with an output of 60 W at an input voltage of 12 to 28 V.
Accenture
Autonomous AI shapes the future
The latest edition of "Accenture Technology Vision" predicts a new era of digitalization: AI systems are increasingly acting autonomously and thus transforming the reality of work in companies. The key success factor here is the trustworthiness of...
Kontron
Managing Board expanded
Kontron expands its Management Board with Philipp Schulz and Dr. Johannes Fues. As COO, Schulz will be responsible for the Aerospace and North America business units, while Dr. Fues will assume the position of COO for the GreenTec business unit.
