Beckhoff Automation
For direct machine integration
The C7015 ultra-compact industrial PC is a fully IP65/67 rated industrial PC for direct mounting on the machine or system.
© Beckhoff
This provides a decentrally installable edge device with high multi-core computing power. In its function as a control computer, the device also reduces the required control cabinet space and simplifies the machine design as well as subsequent system expansions.
The 85 mm × 167 mm × 43 mm fanless Industrial PC from Beckhoff Automation is equipped with an Intel Atom multicore CPU with up to four processor cores. An Ethercat-P connection is integrated.
