Schubert System Electronics
Excellence in industrial interaction
Within its modular range, Schubert System Elektronik GmbH develops box and panel PCs for many areas of application. Numerous expansion options in hardware and software as well as edge computing concepts enable customized solutions to meet specific requirements.
From the sensor to the cloud
Schubert System Elektronik (SSE) stands for 50 years of development experience in the field of industrial computer systems. The portfolio ranges from sensors to the cloud, from hardware and software to assemblies and complete systems. Customers are companies and OEMs in the fields of mechanical engineering, automation, medical technology and more.
In the course of this year's anniversary, SSE is consistently expanding its innovative strength as a digital integration specialist for all relevant technologies in terms of operating concepts, products and user interfaces for Industry 4.0 under the motto "Excellence in industrial interaction". The current highlights include two products: The Prime Box Pico as one of the smallest industrial box PCs and the PC-based HMI and web panels with versatile expansion options.
Compact box PC for connectivity and edge computing
Within the modular range of industrial computer products of the Prime Cube® product brand, the Prime Box Pico is one of the smallest configurable industrial box PCs. Thanks to its very compact design, it fits into the smallest gap in the control cabinet and is characterized by a robust system design. The passive cooling ensures a long service life. Connectivity can be enhanced as required with WLAN, LTE or other radio extensions. A robust, fast and simple fieldbus is also available with the optional CAN bus extension.
Various hardware components and the development of individual edge computing and software concepts are also available for expansion. For example, virtualization tools such as a real-time hypervisor can be used to integrate existing remote maintenance solutions and run Docker-based applications in parallel. If the range of functions of the Prime Box Pico is not sufficient, this can be increased via the expansion interface.
From the BIOS level to operating system configurations and middleware, the SSE experts can develop customized software solutions for the IIoT that meet specific requirements.
Touch panel PCs for convenient and reliable interaction
The PC-based HMI and web panels for the visualization of industrial applications can be implemented in various diagonals as built-in and surface-mounted versions and can be integrated into any modern machine design.
Thanks to the robust system design, passive cooling and IP65 protection class, the devices can also be used in demanding environments. The operating system and BIOS can be preconfigured on request.
The galvanized sheet steel housing with powder-coated front frame ensures high mechanical stability, while the tempered and anti-reflective glass front ensures optimum usability.
The projected capacitive touch technology (PCT) enables convenient and modern interaction. Based on SSE's expertise in touch parameterization, individual requirements such as glove operation, water detection or a cleaning mode can be implemented. Factors such as EMC-stable 4-finger operation and palm detection are pre-parameterized as standard.
Everything from a single source
With the brands Prime Cube® for high-quality industrial computer products and BK Mikro® for reliable monitoring systems, Schubert System Elektronik, based in Neuhausen ob Eck near Tuttlingen in Baden-Württemberg, develops and manufactures customized systems, from the initial idea to series development and support, with around 170 employees and an international partner network. Innovative strength "Made in Germany".
To strengthen its development expertise in the field of system software, the company founded the Software Lab in Deggendorf, Bavaria, in summer 2020. In cooperation with the main site, a young team there develops Linux-based automation and client applications such as web panels as well as applications and frameworks at the middleware level.
As a member of the Schubert Group based in Crailsheim, Schubert System Elektronik GmbH is part of a globally active family business with around 1,300 employees.
Direct contact:
Take-off Gewerbepark 36
78579 Neuhausen ob Eck
email
