IBM Watson IoT
The projects in the Industry Lab
IBM opened the Watson IoT Center in Munich on February 16, 2017. Computer&AUTOMATION was able to take a look inside the Industry Lab, where IBM is working with partner companies on a wide range of Watson projects.
Company for this article
Topics and products in this article
Is your company active in these markets/areas?
Watson projects and the partner companies
IBM opened the Watson IoT Center in Munich on February 16, 2017. Computer&AUTOMATION was able to take a look inside the Industry Lab, where a wide range of Watson projects are being worked on with partner companies.
Martina Koederitz hands over management
IBM has announced that Martina Koederitz will no longer manage the business in the DACH region. The position will be taken over by Matthias Hartmann, who is returning to IBM after several years at other companies. Koederitz is moving to the global...
IBM cooperates with industry
IBM wants to drive quantum research forward together with industry and has also gained Daimler as a partner. The automotive group wants to research how quantum technology can be used to develop potential applications for the automotive industry.
Machine learning you can touch
Hilscher, IBM and X-Integrate showcased an intelligent cloud solution for automated quality management at SPS IPC Drives 2017 in Hall 2.
Growth spurt through artificial intelligence
Corporate profits will rise sharply thanks to artificial intelligence: This is the conclusion of an Accenture study. But which sectors will benefit the most?
Bosch relies on the cloud from IBM
Last year, Bosch announced that it wanted to set up its own cloud. Was this announcement perhaps too grandiose after all?
Head office opened in Munich
IBM has opened the doors to its new global Watson IoT headquarters in Munich. Around 1,000 employees are to explore the technical and economic potential of the IoT there - together with well-known companies.
Watson technology for Mindsphere
Siemens and IBM plan to integrate Watson technology into the Mindsphere platform. The aim is to further simplify the use of data analysis functions for customers.
ODVA, OPC Foundation, PI and VDMA
Specification for interoperable energy management published
Precise energy consumption data is needed to achieve climate-neutral production. A consortium has now published a specification for interoperable and efficient energy management in industrial automation and process automation.
