Unitronic
Security-relevant applications in mobile communications
Unitronic presents the RUT955 dual SIM 4G/LTE and WiFi mobile router from Teltonika Networks.
© Unitronic
It is equipped with Ethernet, digital and analog I/O, RS232, RS485, GNSS (GPS), microSD and USB interfaces. A wide range of functions are available, especially for safety-relevant applications in mobile radio and GPS tracking. External antenna connections make it possible to use individual antennas to find the best signal location.
The router supports LTE Cat 4 with speeds of up to 150 Mbps. According to Unitronic, it also has four 10/100 Ethernet ports as well as a WAN port (can also be configured as a LAN) and three LAN ports.
It supports network protocols such as TCP, UDP, IPv4, IPv6, ICMP, NTP, DHCP, DNS, HTTP, HTTPS and many more.
The RUT955 comes with the advanced software features of 'RutOS' such as Modbus, SNMP, TR-069, NTRIP, MQTT protocol support and a custom GNSS tracking protocol compatible with Global AVL tracking platforms.
Unitronic
Interface diversity
Unitronic has added the TRB 245 and TRB 255 industrial gateways from Teltonika Networks to its in-house 'Sensor2Cloud' portfolio. The TRB 245 is a small industrial LTE Cat 4 gateway with a variety of input/output, serial and Ethernet connections
Advertorial
Simply into the cloud. But safely!
With Anybus Edge, HMS Networks offers a complete solution for cloud connectivity at the production level. The solution closes the gap between production and the cloud and enables users to implement the Industrial Internet of Things (IIoT) easily and...
Unitronic
Interface diversity
