Indu-Sol for SPS Connect
Preventive maintenance of networks
The Profinet-certified Promesh P10 industrial Ethernet switch from Indu-Sol not only allows communication to be controlled, but also permanently monitors the quality of the cables.
In addition to shield current measurement, the current generation of the 'Promesh' family also includes line diagnostics.
For this purpose, the real signals are recorded in their form and fed to a special data matrix. Together with an AI-like analysis, clear conclusions can be drawn about the line quality based on the transmission quality of the signals.
The line diagnostics not only provide information about the quality of the connection during commissioning, but also enable fully automated, preventative maintenance of the network connections over the entire life cycle of the system, replacing the previous line certification, according to the manufacturer. In the event of sporadic, non-reproducible events, for example, permanent monitoring can quickly clarify whether a defective cable or EMC influences were the cause or whether the fault is to be found elsewhere.
Would you like a little more?
First-hand news every week - that's what the Computer&AUTOMATION newsletter offers you.
© WEKA Trade MediaSubscribe to our newsletter and keep your finger on the pulse of automation. Stay up to date with us. We provide you with the latest news, exciting interviews, guest commentaries, application-oriented technical reports and new products.
