Bihl+Wiedemann at the SPS 2021
OpenSafety integrated via Powerlink
The latest addition to the family of ASi-5/ASi-3 fieldbus gateways from Bihl+Wiedemann is the ASi-5/ASi-3 openSafety via Powerlink Gateway BWU3865.
© Bihl+Wiedemann
It has two ASi-5/ASi-3 masters and is therefore able to communicate in two ASi networks simultaneously as an ASi-5 master and an ASi-3 master. The onboard web server also allows easy diagnostics and remote maintenance, while the integrated OPC UA server enables integration into Industry 4.0 applications. In addition to ASi Safety and Safe Link, the safe fieldbus protocol openSafety is also integrated via Powerlink.
According to Bihl+Wiedemann, the gateway also has three two-channel safe inputs, which can be expanded by up to 62 two-channel safe inputs. Six fast electronic safe outputs and a chip card for storing configuration data are also onboard as standard.
Bihl+Wiedemann
Perfect mix of ASi-5 and ASi-3
Automated material flow lines in modern conveyor systems are often several kilometers long. Standard and safety signals as well as simple and complex tasks need to be managed here. Combinable ASi-5 and ASi-3 solutions are predestined for these...
Bihl+Wiedemann
First ASi-5 safety modules
With the BWU4209 input modules for potential-free contacts and BWU4210 for optoelectronic protective devices, Bihl+Wiedemann presents the first products with ASi-5 safety technology for complex safety sensors and applications.
Bihl+Wiedemann
Innovation partner for automation
Bihl+Wiedemann is a medium-sized, owner-managed company - founded in 1992 by Jochen Bihl and Bernhard Wiedemann in Mannheim. It develops and manufactures complete solutions for functional safety and data communication in machines and systems.
