Turck
IO-Link portfolio expanded
Turck is expanding its IO-Link portfolio with a robust IO-Link master with M12 power supply, a compact IO-Link master in IP20 and an I/O hub with additional power supply.
With the TBEN-L-8IOL IO-Link master with L-coded M12 power supply, which allows currents of up to 16 A, energy-intensive devices such as grippers can be supplied with up to 4 A each. As an IP69K device with an extended temperature range of -40 to +70 °C, the block module is particularly suitable for direct installation on the machine. The IP20 master FEN20-4IOL from Turck, which can connect four IO-Link devices, is designed for use in confined spaces. Both masters facilitate the integration of IO-Link devices in Profinet applications through 'Simple IO-Link Device Integration (SIDI)'. This allows the devices to be integrated directly in the engineering tool. The TBIL-L-16DXP-AUX I/O hub with additional power supply is suitable for applications with increased power requirements. It connects up to 16 digital inputs or outputs with universal ports to an IO-Link master.
