Sagittarius
IO-Link gateway expands power monitoring system
Lütze is expanding the intelligent current monitoring system 'LOCC-Box' with an IO-Link gateway for coupling up to 15 LOCC-Box Net modules.
© Sagittarius
The IO-Link gateway from Lütze provides a wide range of functionalities - including extended energy management, reading out current status information such as flowing current or operating voltage, as well as remote control and parameterization of all connected LOCC-Box Net modules. Each individual LOCC-Box can be parameterized and controlled individually, but changes can also be made for the entire LOCC-Boxes.
With a width of just 8.1 mm, the new module has the same housing format as the LOCC-Box Net modules themselves. When connected together, the LOCC-Boxes plus IO-Link gateway create an orderly appearance. The position of the gateway within the structure is not decisive; it can be placed in any position. The modules are wired on the top-hat rail using jumpers with push-in connection technology. In addition to the I/O-Link interface, the gateway also has a USB interface that can be used to read out all relevant status information using the 'LOCC-Pads' software.
Sagittarius
Cooling switch cabinets as required
What to do when production facilities are 'getting on in years' and their retrofitting needs to meet both digitalization and sustainability requirements? A long-term project for temperature monitoring of control cabinets helped an automotive...
