Vision & Control
Spot lighting with directional light guidance
27 spotlights with directional light guidance for industrial image processing are being launched by Vision & Control. Thanks to the modular design, users can configure the right lighting device for their specific purposes.
The spotlights in the SLE, SLB and SLF product families from Vision & Control are based on LED technology and have low power consumption. The light sources remain cool even in continuous operation. Depending on the model, the spotlights are available for different areas of the light spectrum - there are versions for white, blue, red and green light as well as for the ultraviolet and infrared range. Three different spot diameters - 100, 150 and 200 mm (each with a distance of 200 mm between the lighting device and the object) - are available. Depending on the version, the optical elements are made of glass or plastic. Within the variants, the user can choose from five different groups. Common features of all variants are protection class III for operation with safety extra-low voltages and protection class IP50.
