Vision & Control
Andreas Mühlbauer | Andrea Gillhuber,
IR reflective coatings are precisely measured
High-quality halogen lamps are coated with semi-transparent IR mirrors. Image processing systems from Vision & Control check their exact placement.
© Vision & Control
To increase efficiency, H7 halogen bulbs in car headlights are fitted with one or more infrared-reflecting layers. This reflects the heat radiation back onto the filament, which means that less electrical energy is required to maintain the operating temperature. This measure increases the efficiency and significantly extends the service life of the lamp. Exact positioning and precise alignment of the reflective surfaces is of considerable importance. This production step is prone to errors because the small lamps are only fixed to their thin connecting wires during this process.
The Thuringian coating specialist GBneuhaus therefore relies on image processing systems from Vision & Control for quality control. The lamps are x-rayed after coating and the edges of the reflective surfaces are measured. At the heart of the inspection system is the intelligent Pictor M58/E camera. The hardware and software for image acquisition and evaluation are already integrated in it. Thanks to its LAN connection and browser-based user interface, quality control can be set up and carried out with practically any PC or tablet in the same network.
The images are provided by the telecentric Vicotar T151/0.26L measuring lens. Due to its parallel beam path on the object side, this lens images objects without perspective distortion. Slight fluctuations in the position of the test specimen therefore have no influence on the measurement result. The diffuse area light FDL06-R633/C provides the transillumination. At 633 nanometers, its wavelength is in the near infrared range. As a result, the infrared-reflecting layers appear as a high-contrast black surface in the image.
The test sequence is created in just a few steps using the vcwin graphical parameterization software. Using the "STRAIGHT PROBING" function, the inspection program first detects the glass edges and then, in the next step, the layer transitions. By combining the detected edges, a vector can be calculated that precisely indicates the position and alignment of the vapor-deposited layers. This ensures that only flawless H7 lamps leave the production line.
Vision & Control
Optimized for blue light
Within the visible spectrum, monochromatic image examinations with blue light are the most effective. The lenses in the Blue Vision series from Vision & Control are specially designed for this spectral range.
3D cameras
Sick and Microsoft cooperate on 3DToF
Together with Microsoft, Sick wants to drive forward the development of commercial industrial 3D cameras and related solutions. These are compatible with a Microsoft ecosystem based on the Microsoft Depth, Intelligent Cloud and Intelligent Edge...
AMA Innovation Award 2025
Submit applications now
The AMA Association for Sensors and Measurement (AMA) is calling on scientists and developers from industry and research to apply for the AMA Innovation Award 2025. We are looking for research and development results in sensor and measurement...
Janitza
Management expanded
Axel Hessenkämper joined Janitza as the new Chief Executive Officer (CEO) on September 1, 2024 and is part of the management team alongside Mr. Janitza, Mr. Müller and Mr. Veidt.
