B&R
Implement image processing projects easily
B&R is expanding its integrated vision system with a smart camera that links a wide range of image processing tasks simply and in real time.
© B&R
For example, if different product versions are manufactured on a machine at the same time, the Smart Camera can check which version it is and whether the packaging print is OK with just one image. One function provides the necessary feedback for downstream functions. As the process variables of the controller are seamlessly integrated into these processes, decisions can be derived from them in real time.
The application developer wires the individual image processing functions of the smart camera virtually in a graphical editor, eliminating the need for time-consuming programming work. According to B&R, even complex tasks can be linked within a few minutes and synchronized with the processes of a control system.
The Smart Camera has the same hardware options as the company's Smart Sensor. Various integrated lenses or a housing variant with a standard C-mount thread are available. The other options include various integrated lighting, FPGA image pre-processing and image sensors from 1.3 to 5.3 megapixels.
B&R
The hovering shuttles!
At SPS 2018, Beckhoff presented a transport system based on magnetically levitating shuttles. B&R is now following suit and wants to set the pace with this technology. Markus Sandhöfner, head of B&R Germany, explains the details of the...
B&R
More space in the switch cabinet
The Acopos P3 servo amplifier from B&R is also available with a through-hole cooler or cold plate cooling. According to the manufacturer, these new cooling variants allow up to 60% of the heat loss to be dissipated into the ambient air outside...
