B&R
100,000 revolutions and more
The Acopos P3 servo amplifier from B&R is also available in a special version without output frequency limitation.
© B&R
This enables motor speeds in excess of 100,000 revolutions per minute in many applications. This variant can therefore be used for applications in machine tool construction, stone and glass processing or woodworking. In the standard version of the 'Acopos P3', the electrical output frequency of the device is monitored. If the output frequency exceeds the limit value of 598 Hz for more than half a second, the movement is stopped and an error is triggered. With the new version of the B&R servo amplifier, the electrical output frequency of the device is not monitored. It is therefore subject to dual-use export restrictions in accordance with European Community Regulation (EC) No. 428/2009.
The servo amplifiers are suitable for spindle motor operations of all kinds. The motors can be controlled in an open control loop and in a fully closed control loop with a cycle time of 50 µs.
B&R
Secure communication between machines
B&R simplifies safe communication between machines and machine parts: With an update to the mapp Safety software, programmable safety functions can also be used in complex machine networks without significant additional effort, according to the...
Lenze
Car tuning for industrial drives
Machines only function optimally if the drives used are adapted to the drive train during commissioning: This requires the parameters of the software in the inverter to be set specifically for the machine. Integrated auto-tuning shortens this...
Overview
The top articles in April
Flexibility and modularity play a role in the most-read articles in April - be it in industrial 5G applications, robot programming and control or the app store for industry. Read for yourself!
B&R
The hovering shuttles!
At SPS 2018, Beckhoff presented a transport system based on magnetically levitating shuttles. B&R is now following suit and wants to set the pace with this technology. Markus Sandhöfner, head of B&R Germany, explains the details of the...
B&R
More space in the switch cabinet
The Acopos P3 servo amplifier from B&R is also available with a through-hole cooler or cold plate cooling. According to the manufacturer, these new cooling variants allow up to 60% of the heat loss to be dissipated into the ambient air outside...
