Products of the year 2021
Image processing - the winners!
It was close right up to the last second of the reader vote in the 'Image processing' category. Here is an overview of the category winners.
3rd place: With the 'VC MIPI Embedded Vision Kit' and a Raspberry Pi Compute Module 3 or 3+ from Vision Components, a fully-fledged and industrial-grade embedded vision system can be set up quickly.
The core component is the 'VC Compute Module Interface (CMI) Board', onto which the RASP CM is simply plugged. The embedded vision kit contains a VC-MIPI camera module including software driver, an FPC-VC-MIPI cable (flexible circuit board) and an S-mount/M12 lens holder. More...
Managing Director Jan-Erik Schmitt accepted the trophy for the 'VC MIPI Embedded Vision Kit' from Vision Components and provides insights into why users have opted for the embedded vision kit.
2nd place in the image processing category
2nd place: For use in harsh environments, Matrix Vision offers a waterproof version of the 'mvBlueCougar-X' industrial camera with the IP67C option. The C in the name stands for compact, which is the main advantage.
The waterproofing has been integrated into the standard housing so that little installation space is required. The plug-in connections can be screwed on. More...
Ralf Grasmann from the company management and Khader Ghattas, Product Manager Industrial Cameras at Matrix Vision, accepted the trophy for 2nd place in the 'Image Processing' category. In the interview, the two explain why the company relies on the modular principle and why an application-specific application from the automotive industry was chosen as runner-up.
1st place in the image processing category
1st place: Sick is expanding its portfolio of camera-based code readers with the Lector61x.
It measures 30 mm x 40 mm x 50 mm and complements the Lector series for reading 1D, 2D and stacked codes. In addition to the logistics and automotive industries, these are used for the traceability of components, particularly in the sensitive and miniaturized electronics and solar industries for electronic component, device and PCB identification. More...
Yuan Xia, Product Manager for camera-based code readers at Sick, accepted the trophy and explained the advantages of camera-based code readers over other technologies.
