Maxim Integrated / Sick
The industry's smallest LiDAR safety laser scanner
Maxim Integrated Products helps reduce the size of Sick's LiDAR-based safety laser scanner 'microScan3 Core I/O' by 50% with software-configurable digital IO products.
Thanks to the software-configurable digital IO from Maxim Integrated, Sick has been able to reduce the size of safety laser scanners by 50 %.
© Sick
With what it claims is the industry's smallest design, Sick is expanding the usability of the 'nanoScan3' safety laser scanner for machines and vehicles that require high performance but have limited installation space available. The developers at Maxim and Sick worked together to optimize the scanner design and replaced several discrete components with a combination of the software-configurable digital IO 'Max14914' and the parasitically powered digital input 'Max22191' as well as other Maxim ICs. This enabled them to halve the size of the 'nanoScan3' compared to the 'microScan3 Core I/O' - the 'nanoScan3' has a height of only 8 cm. Due to this reduced size, the laser scanner can be flexibly mounted on various autonomous guided vehicles (AGVs), mobile platforms and robots, allowing them to navigate safely in the confined areas of warehouses and storage facilities.
Sick
Paving the way for digitization
'We Create Digital Transformation' was Sick's trade fair motto to present intelligent sensors as pioneers of digitalization as well as digital services and software solutions based on their data.
Sick
Works in confined spaces
With the InspectorP61x, Sick is launching a compact all-in-one 2D vision sensor that enables inline vision inspections even in the tightest of spaces or mounted on robots.
