Basler
Easily implement multi-camera systems
Basler is launching seven interface cards with a GigE Vision interface under its own brand, expanding its existing portfolio.
© Basler
The interface cards with 1GigE, 1GigE PoE and 10GigE have 1 to 4 ports, making it possible to implement various multi-camera systems. According to Basler, additional switches can be used to add more cameras for even more applications in a network, in which they can each transmit the full data bandwidth. The GigE interface cards are required if the PC used only has a single LAN port, which is occupied by the machine controller, for example, or does not have a PoE function for the power supply.
The cards are divided into a standard and a premium product line. While the standard cards are designed for robust image acquisition and are divided into 1GigE cards with 1, 2 and 4 ports and 10GigE cards with 1 port, the premium cards for demanding applications include 1GigE PoE cards with 1, 2 and 4 ports and integrated power supply via the same data cable using Power over Ethernet.
Rauscher
Precision in the large field of vision
Rauscher has six 'Basler boost' cameras with sensors from the 'XGS' series from ON Semiconductor. According to the supplier, the CoaXPress cameras are suitable for applications that require high resolutions and precision in a large field of view.
Vision & Control
Optimized for blue light
Within the visible spectrum, monochromatic image examinations with blue light are the most effective. The lenses in the Blue Vision series from Vision & Control are specially designed for this spectral range.
IDS
AI marketplace launched
On the IDS virtual AI marketplace, end customers have access to complete image processing solutions and can choose the right, ready-made application. This should open up new opportunities for image processing projects, especially for SMEs.
