Cognex
Access to IIoT data
The Cognex Edge Intelligence (EI) platform from Cognex helps monitor barcode reader performance and device management to reduce downtime and increase productivity in manufacturing and logistics processes.
© Cognex
Within minutes of installation, the EI software begins securely capturing important device data and displays the results in visual dashboards. Customers can use it to analyze performance trends, monitor configuration changes, and capture images of unread and failed validations for further analysis.
The Cognex platform can monitor multiple devices and assets in one location, as well as deploy configurations and firmware updates to a large number of connected devices simultaneously. It includes audit trail capabilities that track and report all changes to device settings and connectivity features for easy integration with other Industry 4.0 solutions.
IOSS
Code reader based on AI
The intelligent code readers in the DMR4XX line from IOSS automatically adapt their reading strategy by continuously improving during the process: the more codes are read, the more strategies the integrated software generates or optimizes.
Compar
Artificial intelligence for image analysis
For soldered connections on printed circuit boards, the switch to lead-free solder causes increased failure rates. Quality control must therefore be improved. However, conventional methods with camera-supported automatic image evaluation quickly...
Cognex
Automated inspection
Until now, optical inspection in 3D was associated with high programming effort and costs, meaning that users had to resort to 2D solutions. A new type of laser-based 3D vision system is now set to put an end to this.
