DC/DC converter
Quelle: Bicker Elektronik | Inka Krischke,
Working in the extended temperature range
The DC/DC converters BDC-10VC and BDCD-10VC from Bicker are fully encapsulated converter modules in a shielded aluminum housing for industrial use in the temperature range from -40 to +85 °C. Two versions are available.
© Bicker Electronics
The 'BDC-10VC' modules are designed for PCB mounting with a 2.54 mm pitch; in contrast, the 'BDCD-10VC' modules with terminal strips can be mounted either directly on the chassis of the application using two fastening screws or on a standard DIN rail using a DIN rail mounting kit. The DC/DC converters deliver a maximum power of 10 W for 24/7 continuous operation and can be supplied with 9 to 36 V(DC) - nominally 24 V(DC) - on the input side. On the output side, models with +5 V(DC) (2000 mA), +12 V(DC) (833 mA) or +24 V(DC) (416 mA) are available as standard. Other output voltages are available on request. The insulation voltage between input and output is 1500 V(DC). The circuit design results in an efficiency of up to 88 %. The integrated overvoltage, short-circuit and overload protection as well as undervoltage protection at the input ensure operational safety. A remote on/off function allows the DC/DC converters to be switched on and off externally via the CTRL input.
Meilhaus
DC power supplies up to 200 W
B+K Precision's 'BK9240' series devices are universal DC power supplies whose multi-range power supplies extend the rated power from a point to a curve, delivering up to 200W over a wider range of voltage/current combinations.
Drago Automation
Four configurable channels
With the 'DN 2050' function signal converter, Drago Automation is launching an individually configurable device that can be used in a wide variety of applications in machine and plant engineering and is particularly suitable for retrofit projects.
