Block at the SPS 2023
Integrated UPS functionality
The 'PEL-4124-013-01' power supply from Block combines a power supply unit with buffering in one housing. This integrated uninterruptible power supply (UPS) offers additional safety and system availability in the event of short-term power failures.
© Block
Thanks to the maintenance-free and long-life ultracapacitors, the Block power supply unit meets all the requirements of the VDE-AR-N 4105 directive with regard to grid stability for central NA protection. The FRT capability also meets the requirements for TOR generators. The compact design enables easy installation in switch cabinets and distribution boxes. In addition to the applications already mentioned, the power supply unit is suitable for a wide range of industrial applications, including automation, control technology, mechanical engineering and many more.
Hall 4, Stand 410
Transformer electronics block
DC on the rise
The energy infrastructure in Germany is designed for alternating voltage. However, a DC voltage supply would be particularly advantageous in industry. The DC Industry project funded by the BMWK is committed to DC infrastructures in industrial...
Eaton
UPS with high efficiency
The '93T' uninterruptible power supply (UPS) from Eaton has a rated output of 15 to 80 kVA and provides a stable power supply for critical applications such as server rooms and small data centers.
