Block
Uninterruptible 24 V (DC) supply
Block is expanding its portfolio in the field of uninterruptible power supplies with four new combination UPSs.
© Block
With output currents of 5 A or 10 A, Block 's switched-mode power supplies with integrated charging and control unit and widths of 55 mm or 62 mm ensure system availability for 24 V (DC) consumers. Available in different versions with and without a communication interface, the combination UPSs in the PCC-1024 series offer safety in the event of mains interruptions by connecting different battery modules. The devices are parameterized either via the rotary switches on the front or via a shock- and vibration-proof USB interface with the free 'UPS Control' software. In addition, up to 150 % for 5 s and a static power reserve of 110 % are available at start-up. As with the power supplies in the 'Power Compact Champ (PCC)' series, there are therefore sufficient power reserves available for the reliable tripping of circuit breakers in the event of a short circuit.
Block at the SPS 2023
Integrated UPS functionality
The 'PEL-4124-013-01' power supply from Block combines a power supply unit with buffering in one housing. This integrated uninterruptible power supply (UPS) offers additional safety and system availability in the event of short-term power failures.
Transformer electronics block
DC on the rise
The energy infrastructure in Germany is designed for alternating voltage. However, a DC voltage supply would be particularly advantageous in industry. The DC Industry project funded by the BMWK is committed to DC infrastructures in industrial...
Eaton
UPS with high efficiency
The '93T' uninterruptible power supply (UPS) from Eaton has a rated output of 15 to 80 kVA and provides a stable power supply for critical applications such as server rooms and small data centers.
