Finder
Working light in the switch cabinet
Finder has a new control cabinet component: The LED lights from the 7L series in various designs provide optimum and energy-saving lighting in the control cabinet, making work on electronic housings and control panels more convenient.
The maintenance-free LED switch cabinet lights can be mounted either magnetically, with screws or with a clip mounting set. Their power consumption is 5 W, the voltage supply is 12 to 48 V(DC) or 110 to 240 V(AC) and the service life is around 60,000 operating hours. Depending on the product type, the luminous flux is 600 or 1200 lumens, which corresponds to the brightness of a 60 or 100 W incandescent lamp in daylight white. The color temperature is 6,000 to 7,000 Kelvin.
Most product variants of the lights have a manual on/off switch, but they are optionally available with an integrated motion detector for greater convenience. Types 7L.26, 7L.27 and 7L.28, on the other hand, have neither an on/off switch nor a motion detector. They can be used as individual lamps via spring pressure terminals, and a maximum of ten lights can be connected in series via plug-in sockets. The 'Ecoline' series requires no plugs or sockets for the electrical connection, as this is made via 2-pole Duo pressure terminals.
