Werma
Signal Light with Segmented Light Function
© Werma
Following the development of 'LineLight Fusion' as a fully integrable signaling solution from Werma, the next development stage now follows with 'LineLight Fusion Segment'.
The new device variant makes it possible to divide the illuminated image into several segments and display machine statuses more precisely, individually and intuitively. For example, two statuses can be signaled simultaneously, thus indicating an even more specific need for action. An automatic scaling function is also possible, allowing process steps or progress to be clearly displayed.
The LineLight Fusion series from Werma integrates the display of machine statuses directly into the machine surface. The flush-mounted, smooth surface of the light module blends seamlessly into the machine housing. The seamless design avoids dirty edges and reliably prevents the ingress of dust or liquids.
With LineLight Fusion Segment, the 200 mm version offers either a continuous light pattern or a division into two 10 mm light segments. From a length of 300 mm, up to three light segments are possible: one continuous illumination, two or three segments, each individually color-controllable. This creates clearly defined segments within the light pattern without the need for additional modules or physical separators. The entire luminaire always remains active, but the individual segments light up simultaneously in different colors - for example to simultaneously signal process status, warnings or approvals. The homogeneous illumination ensures a clear, uniform display and enables very good visibility even from a greater distance. As an option, a loud buzzer can be integrated to provide additional acoustic notification of important machine statuses. Various mounting options are available: The modules can either be screwed in place with variably adjustable clips or attached with industrial adhesive tape. Flexible positioning is possible thanks to movable adapters. Protection class IP54 is achieved. Thanks to a special sealing concept, the luminaire protects the inside of the machine against the ingress of dust and water when installed with protection rating IP65.
Lapp
Authorized distributors made visible online
Lapp is expanding its digital service portfolio and is the first B2B industrial company to provide its authorized distributors with a verifiable online seal from authorized.by. The company aims to create more transparency and security for buyers and...
ZVEI
Rittal wins Electrifying Ideas Award 2026
The ZVEI has chosen Rittal as the winner of the Electrifying Ideas Award 2026. With this award, the German electrical and digital industry honors innovations and solutions that use energy efficiently, conserve resources and have an economic and...
