ipf electronic
Multicolor LED light with touch function
With the 'EZ550320', ipf electronic is launching a compact multi-color LED light with touch function - for example for acknowledging or signaling on a control unit - and an acoustic signal transmitter.
© ipf electronic
The recessed LED signal light (red, yellow, green) is particularly suitable for easy integration in machine control panels, on machine housings or control cabinets, for example to signal faults or indicate certain system statuses. If required, the ipf light also generates an audible signal tone (85 dB) that can be heard from afar. Despite its compact design - the diameter is 55 mm - the light signal of the robust light in IP65 or IP69k is clearly visible from all sides. A 5-pin M12 plug is used to control the colors, the alarm tone and the push-button signal. The light is fastened with an M30 lock nut. Alternatively, a mounting bracket is also available.
Financial year 2025
Lapp grows primarily in Asia
According to preliminary calculations, the Lapp Group generated revenue of over EUR 1.9 billion in the 2025 financial year (October 1, 2024 to September 30, 2025) (2024 financial year: EUR 1.8 billion), thus continuing its revenue level of 2023...
Lapp
Changes in Corporate Management
Matthias Lapp is handing over his role as CEO of the EMEA region (Europe, Middle East, Africa) to Michael Seddig with effect from April 1, 2025. Lapp himself will concentrate on his duties as Chairman of the Lapp Group.
