Rafi
Signaling of three operating states
Rafi is expanding its 'Rafix 30 FS+' range of control and signaling devices to include an LED signaling light with a stainless steel front ring that is just 3.45 mm flat and is suitable for signaling three signaling states thanks to its integrated red and green LEDs.
© Rafi
Its translucent cover, which is neutral white when not in use, indicates the regular operating status with green illumination and faults with red illumination. The indicator light has separate, reverse polarity protected connections for 2.8 mm x 0.8 mm blade terminals and operating voltages from 8 V(DC) to 30 V(DC).
According to Rafi, the signal lights have IP65 protection on the front and are dimensioned for standard installation openings of 30.3 mm.
With a collar diameter of 34.5 mm and an installation depth of 31.85 mm, the recessed lights are suitable for a grid dimension of at least 35 mm.
Harting
RJ45 replaced
With the 'XTS' transport system, Beckhoff enables flexible machine concepts with highly individualized product transport. In the current generation, an Ethernet interface from Harting replaces the RJ45 interfaces of the computer cards. What are the...
Dold
Enclosed in accordance with standards
In order to turn an electronic assembly into a functional module for installation in the control cabinet, a suitable housing is essential. The requirements for this go beyond packaging and protection for the electronics. What needs to be considered...
Rafi
Placed directly on the touchscreen surface
Rafi equips the 'Glasscape' touchscreens with haptic operating solutions: The Flexscape One and Flexscape Wheel control elements are placed directly on the touchscreen surface and enable safe function control without visual contact.
Rafi
Illuminated pushbutton with 5 V supply voltage
Rafi is now offering twelve additional versions of the 'Lumotast 16' series illuminated pushbuttons with an operating voltage of just 5 V for LED control. This makes these actuators, which are designed for standard installation openings of 16.2 mm,...
