Rafi
Signaling of three operating states
Rafi is expanding its 'Rafix 30 FS+' range of control and signaling devices to include an LED signaling light with a stainless steel front ring that is just 3.45 mm flat and is suitable for signaling three signaling states thanks to its integrated red and green LEDs.
Its translucent cover, which is neutral white when not in use, indicates the regular operating status with green illumination and faults with red illumination. The indicator light has separate, reverse polarity protected connections for 2.8 mm x 0.8 mm blade terminals and operating voltages from 8 V(DC) to 30 V(DC).
According to Rafi, the signal lights have IP65 protection on the front and are dimensioned for standard installation openings of 30.3 mm.
With a collar diameter of 34.5 mm and an installation depth of 31.85 mm, the recessed lights are suitable for a grid dimension of at least 35 mm.
