Plug connector
Quelle: Hummel | Inka Krischke,
Relaunch with quick-release fastener
Hummel is relaunching the M40 connector series, which is now also available with the 'Twilock-S' quick-release fastener. This variant is pluggable with the 'Speedtec' locking system.
© Bumblebee
According to the manufacturer, a minimal twisting movement is enough to reliably lock the connection. 'Twilock' is vibration-proof and complies with protection classes IP67 and IP69K when mated. The angled appliance coupler has been given a facelift in terms of design, making it more compact and robust. The overall height has been reduced compared to its predecessor model. In addition, the 'M40 elbow' has a stable rotating mechanism. This allows the cable outlet to be aligned in a radius of around 330° according to the respective requirements. The connectors are suitable for high-current applications and are preferably used on powerful motors. There is a choice of 6-pin and 8-pin versions.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
Data routing
Protocol-independent connection
Production in I4.0 is based on the networking of machinery data with traditional IT applications. The availability of process data allows applications such as control stations, big data analytics, predictive maintenance and KPI monitoring to be...
