Drives
Günter Herkommer,
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
© Siemens
For worldwide use, the new device variants of the Sinamcis S210 have an optional supply rail system and a common DC link coupling. The latter enables energy compensation during dynamic reversing processes, which reduces the thermal waste heat generated during braking via the integrated braking resistor and increases the travel cycle of the individual axes. In addition to the S7-1500 Advanced Controllers, Simatic ET 200SP CPUs (Central Processing Units) and Open Controllers or Simatic S7-1500 Software Controllers can also be used as higher-level controllers in the new devices, all of which are connected via clock-synchronous Profinet IRT. Further new variants will extend the power range of the Sinamics S210 devices from 0.4 to seven kilowatts and the associated Simotics S-1FK2 servomotors with axis heights of up to 100 millimetres.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
Data routing
Protocol-independent connection
Production in I4.0 is based on the networking of machinery data with traditional IT applications. The availability of process data allows applications such as control stations, big data analytics, predictive maintenance and KPI monitoring to be...
