Data routing
Quelle: Janz Tec | Inka Krischke,
Protocol-independent connection
Production in I4.0 is based on the networking of machinery data with traditional IT applications. The availability of process data allows applications such as control stations, big data analytics, predictive maintenance and KPI monitoring to be implemented.
© Janz Tec
Janz Tec and 'Verlinked' provide the necessary solution for the protocol-independent connection of heterogeneous industrial controllers with the verlinked API Gateway. The 'verlinked API Gateway' provides an easy-to-integrate out-of-the-box solution for flexible access to machines and systems. The integration solution for cross-manufacturer and cross-protocol access to process data from machine control systems can make data available to any number of IT systems. The connection is established using preconfigured adapters for communication protocols such as CAN, MQTT, HTTP and OPC UA. The information model of the 'linked API gateway' allows binary process data to be mapped into more complex data objects, which can then be processed directly in an IT application. Freely configurable interfaces enable integration without additional programming effort. Flexible routing means that all data is available simultaneously in different IT applications and systems.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
