Gateways
Quelle: Pepperl+Fuchs | Inka Krischke,
Read out diagnostic data more easily
Pepperl+Fuchs launches the LB Profinet gateway, enabling full access to all connected HART devices in addition to the conventional Profinet functionality.
© Pepperl+Fuchs
In practice, HART auxiliary variables are therefore available to the user as secondary measured values in addition to the process variables. Furthermore, the diagnostic data of the field devices can be read out via HART-IP - this significantly increases transparency and system availability. The gateway also offers flexibility, as different protocols can run over the same connection cable. Up to 80 field devices can be connected to a fully occupied remote I/O system and communicate without any time delay. The gateway has an intelligent redundancy concept: an integrated switch guarantees the function of the network at all times based on the Medium Redundancy Protocol (MRP). If a line fails, the ring network is reconfigured to route data packets via the alternative route. The device status and other diagnostic data can be read at a glance via RGB LEDs on a large display.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
Data routing
Protocol-independent connection
Production in I4.0 is based on the networking of machinery data with traditional IT applications. The availability of process data allows applications such as control stations, big data analytics, predictive maintenance and KPI monitoring to be...
