Sagittarius
Power distribution in the switch cabinet
With Wöhner and the 'CrossBoard', the central energy distribution system is mounted on the 'Airstream' wiring frame from Lütze.
© Sagittarius
The CrossBoard from Wöhner is a modular basic busbar system that can be used to quickly implement power distribution systems up to 160 A. In conjunction with the rear feed, the combination of Airstream from Lütze and CrossBoard opens up new possibilities in terms of sustainability and efficiency in installation and wiring. The CrossBoard lengths are compatible with the standard enclosure widths and Airstream wiring frames. Once the busbar system has been installed, it can be fitted immediately with components that are snapped on without tools, and the contacts are made directly. The integrated reverse polarity protection prevents errors during installation, while the contact hazard protection makes it easier to work with live components. A wide range of Airstream accessories such as wiring combs, wire holders or airblades can be mounted directly on the CrossBoard.
Igus
Draw-wire sensor for energy chains
Igus offers users the "i.Sense-EC.B" system with a new cable tension sensor for monitoring the condition of chains over 35 m in length. This allows potential chain breakages to be detected even over very long travel distances.
B&R
The climate always in view
In control cabinets, the waste heat must be dissipated and monitored as effectively as possible. But is an extra measuring box in the enclosure really necessary for this? A pragmatic approach.
