Gogatec
More structure in the control cabinet
The Gogaswitch VK slotted wiring ducts from Gogatec help to set up an orderly and protected cable routing.
© Gogatec
Made of flame-retardant rigid PVC, the wiring ducts can be installed precisely thanks to the standard-compliant base perforations in accordance with DIN 43659. All variants are deburred, have break-out side punchings for precise cable routing and are VDE and cCSAus approved.
The trunking is supplied in the color RAL 7030 and as 2 m long rods. According to Gogatec, wire retaining clips, retaining tongues, expanding rivets and a cable duct cutter are available as accessories.
Eplan
The benefits of data standards
Fully digitized data is the driver for optimizing engineering in control and switchgear construction on the basis of a digital twin. This means that the corresponding article and device data must be available right at the start of project planning.
Finder
Working light in the switch cabinet
Finder has a new control cabinet component: The LED lights from the 7L series in various designs provide optimum and energy-saving lighting in the control cabinet, making work on electronic housings and control panels more convenient.
