Gogatec
Securely screw together corrugated conduit hoses
According to the manufacturer Gogatec, the Gogacon PA-K1 conduit fitting with cable seal ensures continuous safety when routing cables.
The Gogacon PA-K1 conduit fitting from Gogatec
© Gogatec
Thanks to its standard-compliant and simple one-hand installation, the conduit fitting from Gogatec fits on different corrugated conduit profiles. The corrugated conduit can be rotated in the fitting, which has high pull-out forces. Several fittings can be placed close together. A simple opening mechanism allows the conduit to be released using the safety opener supplied. The simple version of the conduit fitting is available in types M16 to M32 or PG for nominal conduit diameters of 10 mm to 29 mm and a clamping range of 4 mm to 25 mm. The versions with UL approval range from M16 to M50 or PG for a nominal conduit diameter of 10 mm to 36 mm and a clamping range of 4 mm to 36 mm. Protection class IP68 (with sealing insert in the UL version), fire class V0 in accordance with UL94 and an operating temperature range of -25 to +100 °C (UL: -40 to 105 °C) are further features of the conduit fitting.
