Current products
Inka Krischke, Davina Spohn | Davina Spohn,
News from the field of electromechanics
© Image: Computer&AUTOMATION, Sources: Leoni, Bopla Gehäuse Systeme, Pepperl+Fuchs, Eaton Electric
Megatron
More precise force measurements
The force sensors of the 'KT705' and 'KT805' series from Megatron have been equipped with analog electronics. This means that the force transducers also provide a negative output voltage or indicate when they are actuated in the opposite direction...
Megatron
Angle measurement in the smallest space
Thanks to their housing depth of just 6 mm and a housing diameter of 16.4 mm, the hollow-shaft conductive plastic potentiometers in the 'MHP16' series from Megatron are particularly suitable as position indicators in motor valves and actuators.
Joysticks
Protected against dust and splash water
The Hall-effect finger joystick of the 847 series from Megatron is manufactured in protection class IP67 and is therefore protected against dust and splash water. Its soft-touch feel enables easy and precise control of work machines in harsh...
