Equipment connectors
M12 power in nine variants
From Hummel, new in the M12 power segment, come nine connector variants plus cable, coupling and right-angle connectors, both user-in-the-field and overmolded. Each model is obtainable in four different codings K, L, S, T.
© Hummel
The designer has options like flange or single-hole, front or backplane mounting, with female or male thread. The portfolio even contains an orientable version with which coding can be oriented in the required direction after assembly. Using special materials, the connector series meets the highest mechanical standards: when inserted ingress grading IP67 and IP69K. The temperature range of K-coded and L-coded connectors approaches +125°C.
IIoT gateways
Based on Raspberry Pi
With the RevPi-Connect, Kunbus introduces the newest member of its Revolution Pi product family to the market. The device, designed as an IIoT gateway for machine and plant construction, is housed in a DIN rail housing.
