Drive technology / motion control
Heiko Füller | Günter Herkommer,
Liquid fruit in compact packaging
A multifunctional palletizing system has recently taken over the entire conveying and handling processes at the Sachsenobst winery. - All in all, a very demanding motion control and drive task.
© SEW-Eurodrive
Between Grimma and Döbeln and between Oschatz and Colditz, strawberries, cherries, currants and raspberries as well as plums, apples and pears ripen in large quantities in Saxony's 'fruit country' under favorable climatic conditions. In the middle of this fertile region, a sweet must and fruit wine press was built in 1936, just outside the town of Döbeln. It is the origin of today's Sachsenobst winery.
Back in the 1980s, plant manufacturer Bayer, which still works for Sachsenobst today, developed a handling system for the hot-filled liquids to reduce the workload of the winery employees. "Fruit juices are filled to the brim at 90 °C, fruit wines at 60 °C. They are then cooled down to around 35 °C so that the aroma and vitamins are retained," explains production manager Luise Hoppe. After all systems and transport equipment were comprehensively modernized in 1997 at a cost of more than 11 million euros and equipped with drives from the manufacturer SEW-Eurodrive, among other things, something happened five years later that went down in the history of the Sachsenobst winery as 'Black Tuesday': The flood of the century in the Freiberg Mulde flooded all the buildings on August 13, 2002, destroying the entire bottling technology. The next flood came in 2013. After that, an extensive renovation of important plant components was necessary, which ultimately resulted in the tender for a new multifunctional palletizing system.
"Our requirements were high," says Johannes Zimmermann, Technical Manager of the Sachsenobst winery, looking back and adds: "The system to be built was to take over the entire conveying and handling processes of the incoming empties, the pallets and the handling of the crates and cartons. We didn't have much space available, as the system had to be installed at the front of our bottling hall. There was only a space of 15 m wide, 10 m deep and 6.50 m high available." Against this background, the decision was made together with the contracted plant manufacturer Bayer to install the palletizing system on two levels. In addition, an automatic pusher had to be installed in this limited space to feed the new glass into production. The system can transport a total of 8000 one-liter bottles per hour.
View of the portal with the clamping jaw gripper
© SEW-Eurodrive
How the material flow works
The material flow in the newly constructed plant is as follows: The filled and cooled bottles are automatically packed into crates by a bottle packer. A spiral conveyor transports these crates to the upper level of the palletizing system. There they first meet the grouping station and the row pusher, which create the layer pattern. A synchronous servo motor drives the row pusher via toothed belts. Specifically, this is a highly dynamic servomotor in a compact design from SEW's CMPZ series. Another four of these servomotors are installed to move the gantry. They drive the rotary axis A as well as the linear axes in the X, Y and Z directions and are equipped with absolute encoders for fail-safe positioning.
Once a layer has been provided, a clamping jaw gripper picks up the entire layer and places it on a Euro pallet. But the palletizer also performs other tasks. To ensure that there are always enough pallets, crates and bottles available, pallets with empties are continuously fed in on a feed conveyor. The palletizer unloads the empties pallets layer by layer and transfers the empties containers to an unloading table. From there, the separated crates automatically reach the bottle unpacker and are then transported to the unscrambler, while the empty returnable crates are conveyed to the crate washer. The empty pallets are stored in a pallet magazine.
View of the palletizing system with the empty goods infeed (top), the pallet magazine (middle) and the outfeed section for the full goods (left)
© SEW-Eurodrive
The disposable bottles are packed in cartons or trays, which are also palletized. Beyer Maschinenbau built a second gripper for this purpose, which is called a louver gripper in accordance with its mode of operation. The special feature here is that after a product layer has been lifted, a blind is moved under the product in order to be able to transport the product safely. This shutter gripper rests on a table in the machine's operating area until it is used. The palletizing system places the jaw gripper on this table and automatically releases the mechanical connection. The system operators then disconnect the gripper from the power and compressed air lines. The gantry then picks up the gripper in two steps. The mechanical connection is made automatically, while the electrical and compressed air lines are connected manually.
Exclusion of the interference areas
The new glass pusher pushes the individual layers from the bottle table onto the hinged belt conveyor.
© SEW-Eurodrive
To ensure collision-free operation of the machine, extensive interference areas had to be defined and excluded from the respective work area. Depending on the gripper head used, some of these interference zones differ significantly from one another. A 'Movi-PLC advanced' motion controller is responsible for coordinating the drive axes. The user program running on it makes it possible to define up to 16 different interference zones. They can be individually configured or activated.
"The implementation requires both fast communication within the drive system within a few milliseconds and a high control quality of the components used. The 'Moviaxis' servo multi-axis amplifiers in conjunction with the synchronous servomotors used offer both," emphasizes Ralf Reinhardt, Head of the Technical Office at SEW-Eurodrive in Meerane. The motion controller controls the axis modules of the system and is in constant data exchange with the higher-level PLC of the palletizing system. The control cabinet was installed on the platform at the height of the upper level based on the experience of the flood disasters.
Specifically, the motion controller used controls the blinds of the blind gripper head, the walking beam, the row pusher and the row sorter of the grouping station. It also operates various actuators and sensors, such as the sensors for monitoring the packing head. If a fault occurs on the packing head, it is processed directly in the Movi-PLC so that the drive axes can be stopped as quickly as possible.
The Moviaxis multi-axis amplifier used in conjunction with the CMPZ synchronous servomotors. The Movi-PLC advanced motion controller used (right) has functions such as electronic gearing, cam disk and robotics.
© SEW-Eurodrive
A standardized process data interface enables comprehensive and detailed specification of user parameters for both kinematic axes and additional axes. All user parameters are configured via an XML file. This can be read both via the higher-level control system via fieldbus and directly into the motion controller. This makes commissioning of the machine very flexible and can be adapted to the respective machine type. This also significantly reduces commissioning times. The kinematics themselves are commissioned using a graphical user interface that requires little know-how. Last but not least, the motion controller used is so powerful that several kinematics can run independently of each other on the same controller.
All in all, the implementation of the described system at Sachsenobst required particularly precise and dynamic kinematics due to the limited space available. In addition, a large number of special functions had to be implemented for this application, such as the specification of segments, each with separately writable parameters for realizing the kinematic movement, the correction of the Cartesian target position during the movement, the generation of a speed profile using so-called overrides or routines to ensure data consistency between Movi-PLC and the superimposed controller.
Author:
Heiko Füller is Market Manager for Drive Electronics and Control Technology at SEW-Eurodrive in Bruchsal.
Fieldbus technology
The future of CANopen
Similar to the automotive industry, industrial automation also requires more and more bus bandwidth. In addition, the cloud is becoming increasingly important in terms of communication. How does the CAN protocol, which has long been established in...
Safety
Unauthorized access fended off
Plant modernizations often require new safety precautions. This was also the case for a manufacturer of cleaning agents and disinfectants, who had to safeguard the material flow in the area of a roller shutter door, among other things.
Gateways
Individual IoT systems
How big? How much power? How robust? Which housing? The requirements for IoT systems are extremely varied. By designing individual embedded applications, devices can be created that are perfectly tailored to the application.
Production software
A digital image
The digital twin accompanies machines and systems throughout their life - from the initial idea to ongoing operation and a look into the future. The aim is to avoid errors, optimize systems and prevent failures.
