Connectors
Just 2 mm contact spacing
TE Connectivity has added to its range of products, with connectors supporting its RITS solution (remote I/O termination system), and enabling speedy and easy connection of cabling with thin leads.
© TE Connectivity
The compact contact spacing of 2 mm (0.79 in) takes up little space on a circuit board. With a maximum rated UL current of 3 A per wire and a rated voltage of 32 Vdc, they are suitable for virtually all I/O applications in a tough industrial environment.
IIoT gateways
Based on Raspberry Pi
With the RevPi-Connect, Kunbus introduces the newest member of its Revolution Pi product family to the market. The device, designed as an IIoT gateway for machine and plant construction, is housed in a DIN rail housing.
