With the help of membrane plates and cable glands from Phoenix Contact, unassembled cables can be routed through the enclosure wall safely and in a space-saving manner. The membrane plates, which extend the CES Multigates feed-through plate product family, fit onto standard wall cut-outs of size B24 heavy-duty connectors. They offer reliable protection against the ingress of dust and water. The expansion of the range of metal and plastic cable glands by several variants and sizes creates more flexible application options. Pressure compensation cable glands offer IP67 protection and also enable climate control at different indoor and outdoor temperatures. This allows humidity to escape safely from the enclosures and housings in the event of overpressure.
