Apra-Norm has developed the 19-inch DIN rail holder 3 U especially for the recessed installation of DIN rail housings on the 19-inch level of cabinets, racks or housings, with integrated TS 35 DIN rail in 425 mm width as standard. Other top-hat rail types, installation widths, heights and depths are possible. The DIN rail, which is offset to the rear, leaves sufficient space for the device and connection technology and enables quick and easy installation. A cover is available to protect the built-in controllers.
