ifm
Configurable signal lights
With the 'DV3xxx' series stack lights, ifm is launching signal lights that are easy to see even in direct sunlight thanks to their very bright LED lights.
© ifm
The devices are robust and meet protection class IP65 for harsh industrial environments. The signal lights have a modular design and can be easily configured. Depending on the application, up to five lights in different colors can be combined and, if necessary, supplemented with a buzzer. The individual segments are plugged onto the base module. The segments are controlled via digital inputs supplied with 24 V(DC). If necessary, individual segments can be replaced or added. A segment with a different color or an additional buzzer can be installed in just a few simple steps. Typical applications for the signal lights can be found on processing machines, assembly lines, packaging machines, filling systems, and many other machines and systems where visualization of states is necessary
Lapp
Authorized distributors made visible online
Lapp is expanding its digital service portfolio and is the first B2B industrial company to provide its authorized distributors with a verifiable online seal from authorized.by. The company aims to create more transparency and security for buyers and...
