Hybrid switch
Quelle: Wöhner | Lukas Dehling,
Housing only 36 mm wide
Wöhner presents Omus, an electronic hybrid switch for resistive loads. It offers hybrid technology with adjustable current monitoring, integrated fuses for short-circuit protection and a safe energy supply via the supplier's 'CrossLink' adapter technology.
© Wöhner
In some industrial sectors, machines are used in which heaters have to be switched on and off very precisely and at high frequency. Up to now, solutions with purely mechanical contacts (contactor) or with semiconductor technology (solid state relay) have been used to switch these resistive loads. The hybrid switch from Wöhner combines the advantages of both technologies in a housing that is only 36 mm wide. It can be used in ranges up to 25 A continuous current. The device combines low-wear semiconductor technology with mechanical contacts. The switch-on or switch-off process takes place at the most favorable time at the zero crossing of the voltage within a maximum of 30 ms. During the switching process of the hybrid technology, the semiconductor contacts switch first. Immediately afterwards, the parallel mechanical contacts also close wear-free, so that the semiconductor contacts can open again immediately, resulting in hardly any heat loss during the switching process. Depending on the clock frequency, up to 66 % waste heat can be avoided. The hybrid switch therefore does not require a heat sink. The maximum switching frequency is 1 Hz due to the switching sequence and to avoid excessive heating. The hybrid switch enables either 3-pole use or the switching of all 3 phases individually in one device.
Electrosil
Dynamic haptic feedback
With the 'Smart-Knob Mini', Elektrosil is expanding its series of intelligent rotary pushbuttons with a compact solution. The rotary encoder combines rotation and pressure functionality in a robust housing with IP65 protection and a glass surface.
Rafi
Illuminated pushbutton with 5 V supply voltage
Rafi is now offering twelve additional versions of the 'Lumotast 16' series illuminated pushbuttons with an operating voltage of just 5 V for LED control. This makes these actuators, which are designed for standard installation openings of 16.2 mm,...
Wöhr
Two new surface-mounted keyboards
Wöhr is expanding its 'Surta' industrial keyboards with versions 15 and 16, which have been specially developed for environments such as medical and dental areas, the pharmaceutical, clean room and food industries, as well as general industry and...
E-T-A
Sensory in view
Intelligent power distribution systems are valuable helpers when it comes to digitalization in the IT rack. Monitoring the IT racks using sensors is a particularly effective measure for increasing system availability.
Ateg
Keyboards with glass surface
Ateg offers capacitive PC keyboards with a glass surface from the French manufacturer Tactys. The glass of the user interface is made of 3 mm thick, hardened white glass, which is robust against mechanical influences.
