Gogatec
Enclosure light in aluminum housing
With the 'Gogaswitch LED A-1000', Gogatec offers a switch cabinet light in an aluminum housing that has a motion detector that switches off automatically after ten minutes.
The switch cabinet light has a 3-pin through plug and a 16 A Schuko socket. The supply voltage is 210 to 240 V at 50/60 Hz. The 10 W LED module provides 1,000 lumens of light output with a light color of 4,000 K neutral white. Thanks to its compact design (400 mm x 60 mm x 40 mm), the luminaire can also be used where space is at a premium. The position does not matter, as two mounting brackets ensure a secure hold, which can be mounted both horizontally and vertically. The Gogatec luminaire operates at temperatures between -25 and +45 °C, complies with protection class IP20 and is CE, EMC and RoHS compliant (standard EN 55015 as of 2013).
