SPS IPC Drives
Color it in and out
Wilbrecht LEDCO, Inc., a subsidiary of Microprecision Electronics SA, is introducing its new CL series of panel-mount LED indicators for industrial and outdoor applications.
© Microprecision
The CL series is 10 mm to fit 14-mm mounting holes. LEDs come in red, green, yellow, blue and bicolor options. Ready wired with internal resistors, these indicators can be configured for voltage up to 60 Vdc or 120/240 Vac. A robust M14 metal housing is designed for up to 0.394-inch (10-mm) panel thickness, and is resistant to shock and vibration. Fully filled with epoxy and fitted with a front sealing gasket, these indicators offer IP67-grade front and back sealing for outdoor use. Possible applications include agriculture and construction, forklifts, cranes and transportation, remote control of forestry or freight handling gear, industrial machinery, military and aircraft. Microprecision Electronics SA is a manufacturer of industrial microswitches and LED indicator lights, with production based in Switzerland and the USA.
IIoT gateways
Based on Raspberry Pi
With the RevPi-Connect, Kunbus introduces the newest member of its Revolution Pi product family to the market. The device, designed as an IIoT gateway for machine and plant construction, is housed in a DIN rail housing.
