Refrigerators
Quelle: Rittal | Inka Krischke,
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the food industry and the process industry.
© Rittal
The cooling units in the stainless steel version meet protection class IP55 and work with energy-efficient hybrid technology. They are available with five different cooling capacities from 1.6 kW to 5.8 kW. The hybrid technology consists of a combination of heat pipe and conventional compressor technology. In many cases, such as when the outside temperature is comparatively low, the heat pipe provides sufficient cooling capacity. As no compressor is required for its operation, energy consumption is very low. The additional compressor cooling only works when a higher cooling capacity is required. As all compressor cooling components are speed-controlled, their operation is also energy-efficient. According to the supplier, the temperature hysteresis is also very low. Thanks to their multi-voltage capability, the cooling units can be operated worldwide at all standard mains voltages and frequencies. Intuitive operation takes place via a touch display, on which the basic settings are made and status messages are displayed. In addition to operation directly on the cooling unit, a smartphone app is also available.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
Data routing
Protocol-independent connection
Production in I4.0 is based on the networking of machinery data with traditional IT applications. The availability of process data allows applications such as control stations, big data analytics, predictive maintenance and KPI monitoring to be...
