Drive technology
Bernhard Sattler, Stefanie Wiesner | Günter Herkommer,
What about 'Drive 4.0'?
Drives are the core component in industrial production. In combination with sensors and software, they enable the digitalization of the production process and thus the transparency of technical processes. In short: Industry 4.0 only works with 'Drives 4.0'.
© Fotolia / industrial view
To make electric drives Industry 4.0-capable, they must be digitally mapped. With this in mind, a corresponding ZVEI working group was established in the fall of 2015. In addition to various drive technology manufacturers, representatives from the mechanical engineering and classification/standardization sectors as well as university research are also involved. At that time, Industry 4.0 was described at a theoretical level: RAMI 4.0, the Industry 4.0 component and the administration shell. The working group took all of this as input and has since implemented and defined it for a specific product group.
So what exactly constitutes a 'Drive 4.0'? In the course of the digital transformation, the drive passes through various stages in the value creation process and throughout its life cycle: from planning and manufacturing to integration into machines, commissioning and finally use in the production process. The standardized, manufacturer-independent provision of data plays a central role in this context.
In order to describe the Drive 4.0, concepts for semantics and classifications are first required that go hand in hand with uniform features, data and functions. The eCl@ss classification system, which is based on international standards, was selected to create a uniform data structure with Industry 4.0 semantics. This system already defines many characteristics of different areas of drive technology. The resulting standardized data is then also the basis for the creation of information models, for example for OPC UA.
Basic structure of the asset administration shell.
© ZVEI
Based on the features and data handling, the ZVEI working group has developed initial proposals for Industry 4.0 functions. Functions were selected that are of particular importance to machine manufacturers and system operators and are often already integrated into the drives - albeit in a manufacturer-specific version. Industry 4.0 functions include, for example, a standardized interface for reading out the fault memory, auto-tuning for uncomplicated commissioning, oscilloscope function for recording signals in real time or energy management for retrieving the relevant consumption data.
A key advantage of a manufacturer-independent description and access level is that machine builders and system operators do not need a separate tool for every drive from every manufacturer. In other words, the standardized interfaces offer third-party software providers the opportunity to bring specialized tools to the market. The data obtained from different sources (drives and other machine functions) can be merged and evaluated thanks to their uniform presentation, opening up new opportunities to analyze and optimize the machine in its entirety.
As is so often the case in life, the devil is in the detail. Standardized cross-manufacturer semantics and definition of functions is a project that requires a lot of resources - especially time. The definition of features for eCl@ss has now been completed for motors and is complete with Release 11 of eCl@ss. However, this still needs to be done for inverters and other components. In addition, the internationalization of the data is
via the IEC.
Many standards already exist for converting a drive into an Industrie 4.0 drive component. It is therefore to be expected that the transition to Industry 4.0 will not be disruptive.
© ZVEI
Work on a standardized data structure with Industry 4.0 semantics is the most advanced. Initial data and functions are available, so the ZVEI working group is now working with nine manufacturers to put the results into practice in a demonstrator - under the motto: The vision of 'Drive 4.0' is becoming reality. The standardized eCl@ss data will be used in an OPC UA information model and two initial functions will be implemented - reading the rating plate and the oscilloscope. The manufacturers provide their drive systems and software expertise to implement a hardware and software demonstrator. The whole process is carried out in close coordination with other ZVEI working groups, as well as with the VDMA Industry 4.0/OPC UA Drive Technology working group and the Industry 4.0 AG1 platform.
The core of the demonstrator from a software point of view are administration shells that are based on the existing hardware and software of the drive systems provided and offer typical Industrie 4.0 functions such as an electronic type plate and the Industrie 4.0 oscilloscope. The corresponding data structures and software interfaces are coordinated between the participating companies in the working group in various stages of development. Finally, the use of the OPC UA standard enables a largely platform-independent implementation of the administration shells. OPC UA supports the exchange of data from different devices as well as their processing and aggregation at the higher levels of production control (MES, ERP, etc.) - regardless of the available communication protocols (TCP/IP and UDP/IP). Both event-driven and procedural programming concepts are used.
The aim is to complete the demonstrator for Hannover Messe 2020.
Authors: Bernhard Sattler is a consultant in the ZVEI Automation Association and Stefanie Wiesner is a consultant in the ZVEI Automation Association.
Voices on Drive 4.0
Sebastian Geis
© Baumüller
Sebastian Geis, Management Consultant at Baumüller Nuremberg:
"New, innovative business models in the context of Industry 4.0 can only be developed together. As a specialist in drive and automation technology, the Baumüller Group covers the entire lifecycle in mechanical and plant engineering and is actively contributing its experience to this project."
Martin Hankel
© Bosch Rexroth
Martin Hankel, Head of Digital Business at Bosch Rexroth and spokesperson for the ZVEI Industry 4.0 Electric Drives working group:
"Industry 4.0 will only become a reality if components and systems from different manufacturers exchange information freely over the entire life cycle. The working group is creating the prerequisites for this and is therefore compiling a 'dictionary' in which the most important vocabulary is defined."
Dr.-Ing. Martin Schober
© Trump
Dr.-Ing. Martin Schober, Advanced Development of Networked Systems at Trumpf Machine Tools:
"The combination and networking of new, smart components creates intelligent machines. Thanks to them, the production process is more transparent than ever before. As a user and provider of digital solutions, we welcome the harmonization and standardization of data and functions promoted by the ZVEI Industry 4.0 Electric Drives working group."
Industrial robotics
Programming via drag & drop
One of the biggest obstacles to the acquisition of industrial robots in medium-sized manufacturing companies is the lack of skilled workers. With this in mind, a new operating system was developed that allows programs to be created easily via drag...
Wireless
In real time without cables
Real-time communication without cables! - In order to increase the flexibility of production plants, this is a much cherished wish. But where exactly is this scenario still failing? What are the possible solutions? And what role do OPC UA and TSN...
