Planetary gearbox
Quelle: Neugart | Inka Krischke,
Use in driverless transport vehicles
With NGV, Neugart has a planetary gearbox in its portfolio that is specifically tailored to automated guided vehicles (AGVs). In AGVs that transport heavy loads in 24/7 continuous operation, the gearbox is usually located directly in the wheel.
© New type
Dold
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine is no longer moving in a dangerous direction, the safety gate can be released immediately when a standstill is detected.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
Virtual HMI
Platform-independent remote access
Usually, the control of processes with a PLC runs fully automatically after the initial parameterization. In some applications, however, it is necessary for the operator or technician to be able to call up and set the process data at any time.
