Faulhaber
Motion controller for small and micro drives
Faulhaber has the compact 'MC 3603' housing-less motion controller in its range, which is particularly suitable for integration in device construction and medical technology applications. With 36 V and 3 A (peak current 9 A), it covers the power range up to approx. 100 W.
© Faulhaber
The motion controller from Faulhaber is suitable for 'normal' DC motors with encoders, brushless drives and linear motors. The I/O scope and encoder interfaces correspond to those of the entire family. USB, RS232, CANopen and Ethercat are available for communication. The motion controller already contains firmware version 'M'. With the new 'MC 3603', the motion controllers now cover the entire range of applications typical for small and micro motors, from the postage stamp-sized 'MC 3001' with 30 W and 1 A (peak current 2 A) to the largest family member 'MC 5010' with 10 A (peak current 30 A), which is designed for control cabinet mounting and has proven itself in the industrial sector in particular. All motion controllers comply with current EMC regulations.
Faulhaber
Motor series extended
Faulhaber has expanded the BXT flat motor series to include gears that are matched to it as well as integrated encoders and speed controllers, which are also unusually short in the axial direction, according to the manufacturer.
Lazy bonnet
New management from January 2022
The management structure at drive supplier Dr. Fritz Faulhaber will change in January 2022. The previous managing directors will hand over responsibility to a five-member management team led by Karl Faulhaber due to their age.
WEG at the SPS 2025
Smart gearbox selection
'Gear ProSelect' from WEG is aimed at all those who are regularly involved in the selection and design of gearboxes and geared motors in mechanical and plant engineering, including design engineers, technical purchasers and OEMs.
Lean technology
Easy to implement
