Nabtesco Precision Europe
Precision gearboxes for the food industry
The gearboxes in the 'Neco' and 'RD-C' series from Nabtesco have a hygienic design with smooth surfaces and optimized seals, making them easy to clean
© Nabtesco
On request, Nabtesco's precision gearboxes are available with special coatings or filled with food-grade H1 lubricants. Thanks to their hygienic design, the gearboxes are particularly suitable for use in packaging machines, filling systems or handling and positioning systems such as scara or palletizing robots. The Neco series are completely enclosed gearboxes with a maximum hysteresis loss of 0.5 arcmin. They are fully protected against corrosion. If the application requires a hollow shaft, the compact gearboxes of the RD-C series are ideal. The hollow shaft offers sufficient space to route data and supply lines as well as drive shafts through the middle of the gearbox to save space.
Nabtesco
The gearbox makes the robot
How precise, strong and fast a robot is depends on the performance of the gearboxes used. In the white paper, you can find out what is important in the design and how your robot can also benefit from the properties of Nabtesco gearboxes.
The "living" e-paper
Screen Edition 2024
Welcome to the first issue of the 'Screen Edition', which opens up a completely new way of reading and informing yourself: With the Screen Edition, we offer you a dynamic and always up-to-date source of information with its finger on the pulse.
Lean technology
Easy to implement
Nabtesco
